1001001
Reading the electronic version of the Construction Manual, I see that Van's recommends using 3M F9460PC VHB tape to bond the trailing edge wedges on control surfaces instead of tank sealant now.
page 05-11:
So here's a question: Is this tape acceptable for bonding the foam ribs in trim tabs and trailing edges, or is it only for use on the AEX wedges?
I can see where the concern might be that the porous nature of the foam rib would not lend itself to use of the tape, but I thought I'd raise the question. Has anyone asked Van's tech support about this before?
page 05-11:
"Use of double-sided adhesive tape makes it possible to keep the wedge aligned all the way through the TE build process. We recommend 3M tape product number F9460PC VHB for this purpose. In the past fuel tank sealant has been used on RVs for this application."
