Smilin' Jack
When I installed the fuel tanks and the situation is the same on the left or right tank, top surface,I have a slight bulge between the number 3 and 4 bolt from the leading edge that go into the reinforcement strip between the leading edge and the fuel tank. None of this was present when every thing was just clecoed together. (both leadings are done)
The skin of the fuel tank does not lay down perfect..anyone else have this situation..I looked at a couple other RV's and noticed either a slight buldge in the same area or a bulge between the horizontal spar screws which thankfully I don't have.
I don't know of any thing to do about this except when filling and priming the skins for paint.
One last question, how do you make one of the balloon
Leak tester, Or the water tester.
Smilin' Jack
Smilin' Jack
