s10sakota
Just a few steps into the fuel tank construction, the manual wants me to bolt the Z brackets to the spar.
I'm wondering if these Z brackets have to come off later again? The top of the Z Bracket gets riveted to the back of the fuel tank so it will need sealed with pro-seal.
So if the Z Brackets do come off again, did you guys just re-use the bolts again later? Obviously I will only use two of the three bolts for now.
I'm not sure I understand exactly what 's going on with these brackets. It's a lot of work to bolt all of these on only to remove them later!
