Michael Burbidge
I've finished my first fuel tank and I am now trying to mount it to the spar. Somehow the holes that I matched drilled in the spar do not fit perfectly. I'm having troubled getting bolts in some of the holes. They are just slightly misaligned. I matched drilled these per the instructions with a #12 drill bit. I'm wondering if it would be ok to enlarge some of the holes slightly with a #11 or #10?
Did you have problems getting the z bracket attach bolts into the platenuts on the spar? If so, how did you solve the problem?
