Keith Williams
After 6 years of liking the tank windows, a leak has developed so I am going to cover them. Have the Van's pre made cover, have removed the access plate, and have the screws, nuts and washers that hold the window out and cleaned.
Seems to me that the way to do this is to put a layer of pro seal on the outside of the windows and bolt the pre made cover into place with the nuts and bolts from the window. Is this the normal way to do this?
Any reason I should take the top off and remove the plastic window and backup bracket?
Have checked forum archives, and unable to find directions from Van's or get a reply from an email to Vans so checking here.
Thanks.
Thanks.
