On dwg 16A it shows the vent bulkhead location offset from the main line run to the outboard rib. Is there any reason for this offset, or can I just run straight from the inner rib to the outboard without the offset? Just want to be sure there's no interference problem down the road when connecting to the fuse vent line.
