Brad_in_Indy
Member
Just wondering about the quick blurb in the plans about using tank sealer/RTV to join the aft ends of the opposite stiffeners together to prevent skin cracking. The plans offer almost zero discussion. So, a few things....tank sealer or RTV? Do you tape off a small area on the ends of the stiffeners when priming them, so the sealer/RTV can adhere to metal directly? Finally, what about moisture/water incursion in a finished and flying plane.....does doing this prevent free flow and draining out of the ends of the elevator?
Thanks so much!
Brad
RV-7
Thanks so much!
Brad
RV-7
