pa38112
When I repaired my right tank I used the Vans tank repair kit and only used every other rivet. To use them all seems like over-kill given that the proseal alone could probably hold the repair cover in place. The fuel sender cover is the same size as the repair cover, and it only has 12 screws holding it on, which is how many rivits are used if you skip every other one. I just don't like drilling more holes than necessary. Any thoughts on this?
Also, I am thinking of using the rubber fuel sender gasket instead of ProSeal on the fuel sender. Do the rubber gaskets leak over time like the cork ones do?
