ultimate10201
Member
I have a leak in my right tank. It?s at the outer rear bottom juncture of the tank?s skin, outboard rib, and rear baffle. Picture shows just where it is.
I have fairly easy access through the filler cap to the corner and could probably seal it from inside with a flashlight, small mirror and a new grease gun with an extension. I found a post where someone had done it sucessfully and I think I could, too.
Sure looks like I could just ProSeal it on the outside, though. I'd be careful to avoid interference with the W423 Joint Plate, naturally.
Anyone have experience with an outside fix like this?
Thanks.
[/IMG]
Thanks.
![2ng8k9f.jpg](/proxy.php?image=http%3A%2F%2F%5BIMG%5Dhttp%3A%2F%2Fi46.tinypic.com%2F2ng8k9f.jpg&hash=66c2252253e26da0098b8710f1cb242c)
