randyintejas
Finally got around to testing my tanks, the left held the balloon for 3 day but, the right would deflate after 2 hours. So I refilled it with air and got out the soap and water. No go, could not find a leak anywhere after trying several times! Determined to find it I decided to fill it with water and what do ya know, found it! Leak is in the wire plug for the BNC connector so, do I attempt to pull the access panel and reseal the wire or do I just put some proseal in the gold connector when I do the wiring for the senders latter? (Edit) thinking this may cause a Conductivity problem?
Thanks!
Edit again.. opened the access panel and resealed. Got both tanks mounted and torqued (excellent fit!!) and installed the roll servo, great day after all!
Thanks!
