Hi all,
Just finished clecoing and drilling my leading edges and tanks (boy fitting those ribs was worth a few unmentionables...). Before I move them upstairs onto the spar, I noticed I ran into the common problem where the tank skin doesn't match the leading edge skin properly at the splice strip. In my case on both wings, the tank nose is leaving a good 5/32" gap between it and the leading edge nose.
I read over in http://www.vansairforce.com/community/showthread.php?t=73876 that many of you guys used a ratcheting strap to pull the tank flush when it's mounted onto the spar. But it looks like most have done this after the splice's tank screw holes have been drilled, the tank's riveted, and ready for final mounting.
I'm wondering would it be any better for me to ratchet-strap the tanks flush before doing all the splice strip, z-bracket, and other tank-to-spar drilling?
I also ran into the problem where fitting the ribs have caused some denting at the nose on both the leading edge and tanks. But apparently that's most times gone away when doing final riveting? I'm hoping when I remove the ribs for dimpling, I'll just lightly pound out the dents from the inside with my flush set and light air pressure (did it before on the elevator @ 20psi). I'm just slightly concerned because there's a nose dent on the underside between almost every rib.
![2013-03-11_21-46-24_zps55416625.jpg](/proxy.php?image=http%3A%2F%2Fi1255.photobucket.com%2Falbums%2Fhh630%2Fsbalmos%2FRV-9a%2520N112SB%2520Construction%2F2013-03-11_21-46-24_zps55416625.jpg&hash=478782dccbf0854929334fe562e231db)
