The instructions say to draw a line 5/16" from the joint strip edge. Then slide the strip between the end rib and skin until the line is centered in the skin holes. This will leave 5/8" of the strip revealed. In actuality 7/8" of the strip is exposed. Unless the 1 1/2" wide strip is narrowed by 1/4", the math just doesn't work. Will this extra 1/4" cause problems later on when fitting the tank to the spar?
Steve
90979
Steve
90979
