Does anyone know where I can order a taller RV 7 instrument panel?
The stock Vans panel will not accommodate the new style GRT EFIS stacked one on top of the other.
Wayne
RV7
Greenville, IN
Aircraft Spruce. 2024-T3 sheet, .063" thick. Clamp the old panel to the sheet, match-drill the holes, and trace the outline. Cut it, rivet a flange on the bottom (or bend it if you have a brake), done deal.
At least that's what I did!
