Takeoff Technique ? Castering Nosewheel
Piper J3
I?ve been meaning to start this thread for while and keep forgetting... My flying history is almost exclusively tailwheel aircraft. Now that I own a 12 suddenly I can ?see? where I?m going on the ground and have discovered (new to me) a good technique to mitigate excess steering input on the takeoff roll.
When you line up, point the nose about 10 degrees to the right of centerline before applying throttle. The aircraft will naturally curve to the left with power. By the time the aircraft comes back to centerline the rudder will become effective and lateral steering can be accomplished without the use of differential braking. Angle can be adjusted based on crosswind as the airplane always wants to weathervane into the prevailing wind. For what its worth?
Basically using a soft field technique for takeoff and landing cuts down on overall maintenance on the assembly and gets you airborne faster.:)
And makes the rudder more effective so that the airplane will go straight even if you don't line up crooked....
Talk to 10 RV-12 owners and you will get 10 different opinions on takeoff, pattern and landing. Hopefully not wildly different. Find the one that works best for you.
Just use the opposite of a free castoring tailwheel technique and everything will be fine.
