Tailwheel ID?
grumman41
Active Member
Can someone help ID this tailwheel assembly? I’ve looked at Flyboy and several pictures but still not 100%. The control bracket has a small amount of wear and I want to make sure I get the correct part.
Thanks!
A couple screen grabs
Looks similar to an OEM Vans and some variants of the Flyboy. See attached pics from the Net..the Flyboy page picture has on similar to yours. Of course you have a single sided Rocket link set-up.
Everything in that photo, aside from the asphalt, can be purchased from www.flyboyaccessories.com
It's a Screaming Eagle fork, lightweight tire, RV/Rocket steering link, and a tow bar axle bolt.
FWIW, I probably made a few of those parts, and some were made by Wayne, Chris, or Blake. Yeah, I recognize them....
Cheers!
