I have asked the mothership support this question but not heard back as yet. The through bolt that attaches the U tail wheel to the fork, calls out the use of two washers but that means in my case the castle nut is not threaded on enough. If I take one washer out its just fine. Has anyone else had this issue and did you go to less thick washers as in 32 rather than 63 thickness or just do away with the outside washer? Also the Tailwheel bearings seem very rough , if it was on my combine harvester, i would discard them but I have read here that it seems normal as they wear in with plenty of grease after 50 hours. Is this the norm ?
