I can't find anywhere in any instructions on when to drill hole for the bolt that attaches the tailspring to the weldament. Now that I have the weldament bolted into the skeleton I think maybe I should have drilled the two in a drill press before installing it.
Is there a preferred time for this? Also does anyone have the correct reamer size for the preferred fit between the tailspring and weldament.
TIA,
TIA,
