David Burke
Member
I am currently trial fitting the tailplane to rear fuselage. The positioning of the holes for the vertical support bars to the rear spar seem somewhat vague. Judging by the drawing the pilot hole positions on the rear spar appear to be in horizontally in line with the rivet hole locations either side but I am not absolutely certain.
A second point is that having drilled the forward attachment brackets to the fuse they then ask for the spacers to be inserted and drilled again. This seems a recipe for disaster and I am going to mark the spacers up from the brackets and drill then on a pilllar drill instead to avoid making the longeron holes any bigger.
