Hi fellow builders, Currently ready to install static system, & it appears that that a static line goes only to the ADAHRS unit & no further forward in the Aircraft. How does the panel mounted Skyview unit know the altitude? I presume the ADAHRS unit communicates electronically with the Skyview? I was contemplating adding small backup Altimeter & Airspeed indicators in case of the Skyview going black one day, does this mean I need to run a separate static line forward? Is this a necessary & good idea anyway? Thanks for any comments...
Also, I have recently completed the F-1211 bulkhead assembly, & am completely mystified as to why the top 4 of the 8 nutplates are attached with AD426 squeezed rivets, & the bottom 4 use CCR-264SS rivets. I had never seen these rivets before & was very surprised when the mandrel pulled straight through! I have followed the Vans instructions to the letter, but cannot think of the engineering reason for the use of these two types of rivets.. Any ideas? Thanks, DEAN...
