CharlieWaffles
I just got done drilling the longeron in the tailcone. Per the plans, the apex of the angle is level with the skin all along the side except as I was drilling the last hole near the forward bulkhead (1006) it curved a bit as I was drilling it. So now there is a very slight raise in the longeron along the 5 holes. In the picture I measured it and it seems to be about a maximum of 2/32" raised in the front. The rest of the skin is even and I believe the critical part is the deck, but will this cause any problems down the road? The other side was drilled ok the entire length.
