madmaveric
Hi all, I pre-assembled my bottom half of the tailcone to check a few things before I prime it (mainly how much brake I need to do on the skins) and found the J-stiffeners on both F-1281 contact all three frames on both sides and I'm not sure of the best way to correct it.
The plans say to either cut the holes out or to bend the stiffeners but when I tried gently bending the channel but it didn't seem to be having the effect I wanted. It appeared that it would put a wavy effect along the stiffener and I didn't want to risk damaging the skin.
I was going to look at cutting out the clearance holes but then noticed the skins may be under-bent as the next skin appears to stick out a bit (appears as if it needs more of a bend from the rivet holes to the stiffener). Given the bend would need to be the complete length of the skin I'm not sure how to do it evenly.
I was just wondering what others had done at this point?
Picture showing one of the contact points.
![IMG_1462-1_zpsuitkivyy.jpg](/proxy.php?image=http%3A%2F%2Fi92.photobucket.com%2Falbums%2Fl24%2F%2FIMG_1462-1_zpsuitkivyy.jpg&hash=4b938ecbb438af39dc2a99bae575f0fb)
