Tailcone
My tailwheel mount was not powdercoated, but no big deal to prep, prime & paint. I am on my 2nd tailcone, as the 1st was formed ridiculously off center. I sent a picture & Van's agreed to replace it. I then put it in the vice between two pieces of wood and finished the forming process. just kept moving & working it until it fit! But that has not been my biggest problem with the tailcone.
One of the F712 side flanges was a bit longer than than the other three, which meant that the face against the fuselage was a bit shorter than it's mate! I reformed the flange radius with a small piece of oak and a soft face hammer. Amazingly enough, it worked quite well and the skin lays nice and flat. Well, I thought I had the old tailcone whipped at that point (made up a bunch more new 4 letter words during the entire process), but alas....
The distance between hole centers on the F711 side flanges were 22/32 and the hole centers in the skin are 20/32. Contacted Van's and they stated that I must not have clamped the A & B sides tight B4 riveting, though I prefaced my email to them specifically stating that they were tight and I included a few pics for support. I drilled all rivets out, separating the two sides & F711 bars. I then clamped each half down to the bench, flange up, one flange at a time and measured from the bench top to the hole centers....definitely 11/32 on each. Well they say that can't happen, but it did. As of now, I will attempt to reform all flanges, shortening each by 1/32". Between now and tonight, though, I may still decide to reorder F711A & B.
Bill Swaim
RV7 - Fuse
