Brandi
We purchased our empennage kit about 95% complete. This week, I began reviewing the build in preparation of attaching it to the fuselage. I've discovered a few discrepancies between the plans and the build and I'd like opinions on whether or not they should be redone and how to go about it.
Problem 1: Short J-Stiffeners
There are a couple of instances where the stiffeners were cut too short and a smaller piece was riveted to the skins to complete the length but it does not overlap the other stiffener. I'm thinking that I should probably drill out the small piece and make it long enough to overlap the other stiffener. It's only the length of 4 rivet holes.
Problem 2: F-1055 R&L Rudder Stop Skin Stiffeners & F-1056 Stop Brace are upside down
They're attached with the open angle facing down instead of up. The skin stiffeners are also attached to the brace with small screws instead of the 470 4-4's that it calls for.
Problem 3: F-1011D Attachment Bar Support Angle
Page 10-13 tells you how to fabricate this angle and place the bolt/rivet holes. What we have is an angle that is 6 1/2" long instead of 7" and contains 7 holes instead of the 8 properly spaced ones that it spells out in the plans. The worst part of this is, if it does have to come off, these 7 bad holes are drilled through the stop doubler and the aft deck with the two end holes also going through the longerons.![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
We'd appreciate any advice anybody has.
