Phil
I'm working on section 10 (Tailcone) and I'm having an issue finding the step to final drill the F-1037A Bellcrank angles.
10-9 Step 3: You separate the pieces.
10-9 Step 4: Not related to the 1037A's
10-9 Step 5: Final Drill the 3/16" attachment holes with a #12.
The next mention of the 1037A's (According to what I can find) is 10-23. This is where you run an AN4 bolt through the 1037A's and the bellcrank bearing.
I can't seem to find a step where you final drill the hole for the AN4 bolt. Since this is for a bellcrank, I want to make sure I hit the exact tolerance for the assembly and eliminate any and all slop.
Does anyone know where this step might be hiding?
Phil
Phil
