cleve_thompson
As I read the plans and manual, on a 9A, the tail tie down bracket rivet and bolt holes are predrilled (the bolt holes are just drilled to 1/8 in.) and the bracket is then installed on the forward face of the rear bulkhead and then the holes are drilled into the bulkhead in assembly. I don't think even my angle drill will get in there, particularly if I have to clamp the bracket in place. I was thinking that I would rather mark the bulkhead with the drilling pattern and drill into the tie down bracket from outside. I think that I can do this carefully enough that I should hit the bracket flange center close enough. I think that this will work but then I am not sure what to do when I then install the vertical stab and try to drill it in assembly from inside the tail.
HELP!!!!
HELP!!!!
