Jermechanic
Hope everyone had a great weekend and got some flying in!! I am having a problem removing the tail spring on my RV6. There is a bit of play and noise in the tail spring- I would like to disassemble and inspect. There is very little access to the tail spring bolt in the bottom rear of the fuselage. The access hole for checking the elevator bell crank is too small to get my hand in. Has any one made a different access hole or how do you access this bolt. We were thinking we may have to cut a new inspection opening under the elevator bell crank access plate/opening. Thanks for any thoughts/ recommendations!
