flydjd
Hi all and Happy Easter,
I have searched the archives to no avail and would like some help please !
Status :- HS mounted with all bolts installed, VS same and Rudder hung but this has some issues. Rudder stops not yet made/fitted.
1. I followed the instruction sequence and drilled the VS to the F-781 attach plate to the HS and have the correct 1/4" offset with the 3 brackets lined up with a straight edge. When I then added the extra washer on the left side between the VS and F-712D up elevator stop the 3 hinge brackets no longer lined up ! To get the brackets back in line I have added washers between the 2 lower left bolts at the base of the VS.
This results in the rudder swing being slightly less to starboard.
Has anyone else been through this scenario and have some people left out the extra washer ? (Or added the others ?)
2. With the rudder in place and the Rod End Bearings set as per the Dwg dimensions my horizontal gap between the rudder counterbalance arm and top of the VS is only 5/32" at the rear and 4/32" at the front. To even this out it requires several turns of the top R.E.B. out and equal number of turns in of the bottom R.E.B.
Now however to achieve the 35? rudder swing the rudder bottom fairing is pushing against the botom fuselage skins.......catch 22
Again has anyone else experienced this interference and also what size horizontal gap between the rudder counterbalance arm and rudder do I need?
I shall check back later as now is Family time on bicycles as it is 21?C here .... we are off to the Biergarten !!!!!!
