I have a few suggestions for those of you who are building the tail kit. If you read ahead to the end, you will find that you need to remove the vertical and horizontal stabilizers to install the tips and the tail cone. Keep that in mind when you build the tail section. So, for example, there is no point in installing the forward stabilizer skin until final assembly. Also the wires to the trim motor do not need to be connected and clamped to the tray, because you will just have to remove them to take the horizontal stab off. The connectors are very tight and you risk pulling a wire out of a connector when pulling them apart. Don?t ask me how I know. If you glue the washers needed for the horizontal stab, they will just fall off when you remove the stab. Figure out which washers you need, but glue them later when you do your final assembly. You need to rotate the counterweight arm to install the stab, so if you install the bolts, you will just have to remove them to get the stab off. I suggest that you get a few hardware store bolts and cut the threads off and grind a point on the shank and use those to hold the counterweight arm in place so you can easily rotate the arm to remove the stab. Also use those tapered bolts to connect the control arm to the anti servo tabs, because you just have to remove the bolt to adjust the linkage. I see no point in installing a cotter pin in the castle nut on the bolt that connects the trim system to the aft bulkhead. The nut will not fall off when adjusting the linkage. If you do as I suggest, be very careful to go back and follow the instructions step by step when you do your final assembly to make sure that you put all of the washers and bolts and cotter pins, etc. in place as called out in the plans.
