When you lay out the tape for mounting the tail cone fairing, the top hole on the bottom is not in the right place. The hole needs to be centered on the tab of the skin. See the 6th picture on my last set of pictures posted earlier. If you drill the hole where the tape shows you to drill, one of the nutplate legs will be off of the skin. There are two ways to solve this problem if you have already drilled the hole. One is to use a one leg nutplate and the other is to use one of those very short nutplates where the mounting holes are closer to the screw hole. If you have not drilled the hole, look at the placement from the inside and you will see where the hole needs to be drilled. Remark the location on the tape so that you can see where it needs to be drilled with the tail cone fairing in place. (You can't see it where it needs to go with the cone in place.) Gus at Van's said that they will come out with a correction.
