I am in the test flight mode in my new RV-4. I know this model is pitch sensitive so before giving rides I want to make sure I know how this airplane flies with weight in the back. I have gradually added weight to the rear seat and today i was carrying 160 lbs. Take off was as expected. No problem. The landings were an adventure. My approach speed was around 85 mph. When i got to the normal 3 point landing configuration the nose wanted to pitch up more that usual. Knowing i could not push the stick forward i kept pulling it back until it quit flying and plopped down on to the runway. It did not feel stable or safe and was not pretty. What am I doing wrong? I had two notches of flaps. Should I use full flaps? Should I come in with more speed and use two pint landings?
Thanks, in advance, for your help.
