I connected the trim bias springs to the control column. When the stick is moved left or right, the spring is shifting where it attaches to the control column strap. When it does, the spring vibrates just like a guitar string with a loud twangggg.
I’m thinking a figure 8 safety wire to prevent it from slipping will cure the issue.
Has anyone else had this problem and what did you do?
