rv7charlie
A quick review of earlier threads seemed to indicate that Mobil 1 synthetic ATF is fine with stock o-rings, etc in the brake system. However, I couldn't determine whether it's ok to use it in an existing system that's had the old (5606?) fluid in it. Is it ok to use it, if I use the ATF to push the old fluid out of the system?
Also, when I bought the ATF ('multi car'), the bottle indicated that some post 2005 models need a different Mobil 1 synthetic ATF. Is either version ok for a/c brakes?
Charlie
Charlie
