I was looking on that auction site this evening for switches for my panel. I am using the VP Sport, so the switches don't have to carry nearly the current as a switch-fuse setup. I want a lighted rocker switch, but not the big carling type.
I saw this pre-built 8-switch-fuse panel that looked interesting. I don't need the fuses, but this looked pretty nice.
http://www.ebay.com/itm/DC-12V-8-Ga...05&prg=10050&rk=2&rkt=6&sd=181434954536&rt=nc
http://www.ebay.com/itm/Vertically-...05&prg=10050&rk=1&rkt=6&sd=181434954536&rt=nc
Has anyone tried something such as this? I have seen some switch panels that are designed for boats that would fit nicely in a plane. Even if you had to change the wiring to aircraft grade, it could be a time saver.
Any suggestions for small, lighted switches for my panel? I do not plan on night flying, so being too bright is not a concern for me. I want to be able to see a light when something is on.
