flyeyes
Hi all.
I thought I understood how to wire switches, but they're not behaving as expected so I'm obviously missing something.
I try to keep all my switches separated by function, with different locations and switch types to help identify the functions once learned.
I'm wanting to use some of the swoopy looking lighted push button switches available from mpja for some functions, but I'm having trouble getting the behavior out of the switch that I want.
There are two switches (and various colors) available, a SPDT that fits in a .75" hole and a DPDT that fits in a 5/8" hole.
So far, I have wired and mounted the larger SP switches as master and aux batttery master and they behave as expected. I wired a jumper between the "common" terminal and the ground for the LED, a wire from the contactor to the "normally open" terminal, and a wire from the common terminal to ground. There is a lighting bus feed to the LED positive terminal.
These switches light up when the bus is powered as expected.
My problem is the smaller DPDT switches. I'm having trouble getting the LED to light only when the switch is active. They have a total of 8 contacts, two for the LED, and three for each side of the switch (common, NO and NC). How do I need to wire these? I though I knew but I'm clearly wrong :/
