az_gila
I actually like the idea of the plans "switch strip" (Steins' terminology...
.. actually F-1003B) under the removable parts of the panel, but I would like to make it a bit deeper to accommodate rocker type switches.
Question - would a new fabricated strip with an extra 1 inch added to the bottom cause any leg room problems.
I would use the same panel (F10105) for the engine control knobs, but probably make it about 1/2 inch less deep. Would it cause any problems if the engine controls are lowered about 1/2 inch from stock?
All of above related to equipment positioning for the present wiring planning.
