gblwy
Hi folks,
I'm looking for inspiration from you technical guys ;-)
Yesterday I fitted the switch panel. The very last screw (low down on the left) went in part way and jammed. I don't think it's a cross-thread. When I try to unscrew it, the hex stand-off post that it screws into just rotates anticlockwise, so I cannot remove the screw.
I can only just see the post rotate (with a torch - flashlight), so cannot grip it with anything.
Any bright ideas on how to remove the screw without damaging the unit, or the front panel?
Cheers...Keith
Cheers...Keith
