SW10599R vs NDM 20004A $$
miyu1975
After speaking to Ken at Vans I have to decided to go with a 9 row cooler and mount it to back of the baffle. This will require a little modification to the baffle I believe, but not as much as mounting it to the firewall. I am trying the see the differences between SW10599R vs NDM 20004A...both are 9 row oil coolers...the SW is $645 vs NDM is $375...so is NDM really only half as good as the SW?
If you wish to consider a 3rd option, Aero Classic makes both a 9 row ($259.50) and a 10 row cooler ($262.95). Both available from Spruce. They are well built, and in my personal opinion, Aero Classic oil coolers seem to exhibit a little better efficiency at dissipating heat into the air flow than NDM coolers. They are lighter weight than a comparable NDM cooler too.
The RV8 in my avatar went thru 3 different oil coolers until we found one that both fits the mounting area physically and cools its heat-monster high-compression ECI Titan IO-360 engine in Texas summers.
First we used the NDM 7-row that came with the Vans kits. It proved to be grossly undersized. Next we used an overkill-sized Aero Classics 13-row and it cooled way too well, but also rubbed the inside of the cowling. I then bought a SW 10599R cooler and oil temps with it are perfect and the unit is a very good physical fit on the cyl 4 rear baffle in the RV8. This SW cooler just screams quality construction, but it was painful expensive. It's the "Cadillac" of oil coolers. In hindsight, we probably should've bought the 10-row Aero Classic cooler and saved over $300.
PS: Lostpilot28 here on the forums installed the 10-row Aero Classics cooler on his O-360 RV7 and reported successful results with both the cooling capacity plus physical mounting on the rear baffle of the engine.
difantly not opposed to the Aero coolers...actually I had been strongly considering the 10 Aero too. Thanks,
