More background on this question
Thanks for the feedback. If anyone who has had their RV-8 engine stumble in a departure stall I would like to hear from you.
When doing the departure stall with full power in my RV-8, I always have the fuel pump on, and the fuel pressure stays steady at 5 psi., the nose pitches down after the break and that is when the engine coughs, stumbles or momentarily cuts out. I do not push the stick forward, but ease the back pressure to allow the nose to lower to a deck angle that will allow a prompt stall recovery. I am a reasonably experienced pilot (almost 1,000 hours) in various single engine airplanes including Cessna 150, 172, 182, Piper Cherokees (which will not properly stall) Citabria, and Cub, but I have never had a plane with this issue. I have had two different experienced instructors ride with me during the departure stall in this airplane, and both have commented that I need to find the problem.
I have had two different shops try to solve this problem. They did fuel flow test, checked the mags, and inspected everything that they could think of. The second shop replaced the carburetor and the problem persists.
I do feel light when the airplane breaks in the stall, but the G meter stays positive, +0.6. The engine (O-320 H2AD with “T” mod. and 9.5 Barrett flow matched cylinders) runs great except for this issue. I am looking for ideas.
Thanks for the suggestions.
Ron Brestel
Marshahalltown, Iowa
