I have problems with the IO 360 superior holes from vans!
Hay, I will tell you my minor story about the holes and mounting of my IO 360 Superior. I think the holes and mounting of the battery and the solanoid (sp) and master switch is ok if you don't have the mags that allow you to use both when starting. My mag made it impossible to get my battery in where I had the box mounted. I ended up moving it down about 1 1/2" and also moving both the master solanoid and starter relay down too. And then, I still have to remove my wires from the Mag to remove the battery. It's not that big of a deal now, but I had the motor all mounted and then to try to move the stuff and have the motor and mount in the way..... pain in the A$$. My advice, On my next RV!!!!, I see where they take the battery box and slit it at the corners in front and put a hinge and pin in it. That way, you can pull the pin and remove the battery from the front.
Also, I think I would move some of the holes that I had pre-drilled from the plans. I hate to say it, but If you installed the engine, at least with a couple of bolts, do your routing of "things" then remove it and do a nice job at putting in the holes. The problem with that is having to plan out everything you want to bring through the fire wall, takes time.
Another thing I would do, Learned this from a group in Dabuque, IA, Again on my next RV! Instead of having the heat come into the middle of the fire wall, Harold in his RV7 has his heat muff on the back set of pipes and has 2 smaller feeds into vents on both sides of the firewall. The smaller feeds look easier to run too.
Well, good luck on the Superior instulation. PS... Do you have the New Metal sump on the motor, or the older composit one. There is a replacement sump if you don't have it yet. It is free and they even pay you to put it in. Easier now, befor you hang all the piping and controls. I'm doing that now, and except for one problem with the mixture cable bracket by the throtel body, I'm done. But thanks to this site, they have given me 2 solutions to the problem.
