Wesael
So how long till someone shortens the wing one bay, stretch the fuse a little, and re spaces the ribs, strengthens some key areas, and hangs a IO-720 on one of these?
The change of a O-360 to an IO-540 (harmon rocket) was about the same % increase in weight for that conversion as the IO-540 to the IO-720.
One thing to keep in mind is the RV-4 started life as a +6g airplane but the RV-10 is only Utility catagory.
I bet it would be a smooth running machine.
