Of course I chose Sunday to try this, so no help is available. I'm setting up my SV-XPNDR-261 to my Skyview and on page 11-15 it tell you the following to which I bid but that was over four hours ago and the unit is still loading up the numbers are all counting up and the top one has started over I do believe. I've searched the forums and found one guy that had turned his unit off during this setup and had to send his unit back to Dynon.
The following instructions were followed to the best of my knowledge.
Got to Set up menu>system setup>serial port set up, then select port I used port #1 then it asked which XPNDR I have the SV-XPNDR-261 and then it says Accept and it's been running like this for going on five hrs.
Anyone have any help for me? Thanks for reading.
Ron
Ron
