I will make positive contact, then tighten 135 degrees
Double check that.. I just did mine. -12 threads, copper gasket should be 90 degrees of turn.
According to my Lycoming O-360 overhaul manual, that plug for the oil suction screen, PN LW-12545, is a 5/8 hex head X 1.00; 20 threads per inch. Proper torque on the AN900 crush washer is 135* for a thread pitch of 20.
Thanks guys!!! I will make positive contact, then tighten 135 degrees and hope for no leaks.
I marked the plug's position before removal.
With a new crush gasket, I tightened the plug to it's original position, then safetied.
1 year, 60 hours later, no leaks...
Luck ??
Luck ??
