Has anyone asked Van's if it is OK to substitute solid AN rivets in stead of the pop rivets? It should be OK for experimental amateur built because solid rivets are stronger, I assume. But what about those of us who intend to register as E-LSA? Can we legally substitute squeezed or driven solid rivets instead of using the blind rivets. I would like to use solid counter-sunk rivets because they can be squeezed perfectly flush. The counter-sunk pop rivets have a rounded top that protrudes above the surface unless the rivet hole is counter-sunk deeper. Doing that results in a hole with larger diameter than the pop rivet head. Or am I doing something wrong?
Joe
Joe
