DaleB
So I've been working on the aileron pushrods. The big ones were pretty easy, even figuring out how to get six rivets evenly spaced around the circumference (that's 19/32, by the way). But the smaller ones... Grrr.
I got the 4130 tubing cut, trimmed, cleaned up just fine. Of course the ends won't fit. OK, no problem, I chucked them in the drill and used some 150 grit to turn them down a little. I was going for a "very snug" slip fit, but as it turns out I undershot a little. They're more of a hydraulic press fit in the ends of the tubing. Of course by the time I figured that out, they were in far enough that they were not coming out for any more turning.
Since I don't have a hydraulic press, I used two blocks of wood with holes drilled to protect the threaded studs, and a 2# plastic dead blow hammer. They're in there and they're not coming out in this lifetime.
So now the ends are in and it's time to put in the rivets, which I am convinced are pretty much unnecessary. I'm using a C-frame to set them. The first time around several of the shop heads were badly clinched (tail offset to one side of the hole). I drilled them out and re-set new rivets, half of which were just as bad.
It seems to me that a -12 rivet is a little long for this job. Is it acceptable to use a -11 rivet instead? Is there some secret to getting these done right that I'm missing? This is starting to tick me off a little, and I've used my last -12 rivet.
