alpinelakespilot2000
For those of you who used the Strobes and More Pro System 4, do you have to use the control plug (the yellow, green, blue wires) or can you just run your power and ground from the buss to the power pak and be done with with it? Stated differently, can you just run power and ground to the unit and and permanently select a flash pattern just by which slots you plug your three strobes into?
Also, I'm assuming this power pak will also drive the combo tail/strobe offered by Vans?
Wiring diagram-- http://www.strobesnmore.com/forms/INSTALLSNMPRO606.pdf
Product info-- http://www.strobesnmore.com/strobes-n-39-more-pro-system-4.html
Thanks for any help.
