This may be a silly question.
I have the Whelan one power supply for all three locations. I have the PS in the fuselage aft of the baggage compartment.
The documentation does not say where to run the gound wire. I called them and they said to put it at the main ground where the MFGR says it is to go. Since this is an experimental, nothing says where to install the ground.
I figure it can be grounded to the PS mounting bracket. I am looking to find out if I can do that or do I have to run it all the way back to the sub panel ground?
