****! stripped bolt?
skidmk
Hi all,, I'm referring this to all the experts out there.....
bellcrank bracket (bolted to spar) was re-installed today after I installed the bellcrank on my QB wing. I think I've over torqued the AN3 bolt. It is not loose, loose (can't turn by hand) but it definetly <sp> is not as tight as the other 3. Can I use a longer bolt? helicoil? blue locktite?
help
Mike
If I remember right, the bellcrank gets bolted through the spar into nutplates on the tie-down bracket (someone correct me here). I doubt you stripped the nutplate. Maybe just replace the bolt?
Worst case, you could always remove the tiedown bracket to see what's actually doing on.
-John
70 inch pounds
is what it took to break some i tested.the little terd seemed to turn forever befor actually breaking. as said earlier the nut plate probally not stripped but the bolt has failed,, but i would seriously reccomend a repair to correct it. try the new bolt see if it will hold. its only about 32" lbs IIRC including drag torque..
