I have a raspberrypi ver3 running the latest Stratux very nicely on my ipad using Wifi.
I need a serial output so I can connect it to my GRT HXr.
I have an 8GB SD card and used Win32Imagewriter to load the original stratux onto the SD card. ( I notice after loading the stratux the 8 GB card is now FAT and 59.9MB max )
GRT says to load the "stratux-serial..." version, connect a monitor and follow instructions to finish the install. I did this the same as above, it replaces the original stratux version with the serial port version.
When I boot up with the monitor connected all I get is a colored square on the monitor.
I know I am omitting a critical step that people are assuming I am doing, assume nothing and tell me how to do it step by step, leave nothing how trivial out.
Thanks Peter
Thanks Peter
