Stratus 2 Mounting
Vac
Benefactor
Hi Folks,
Any suggestions or experience with mounting or using the Stratus 2 in the RV-4? We just purchased one and the silicone pad and clip won't work on the side of the canopy due to the compound curves...
Thanks!
Vac
Ram mount
I used a mount purchased from Ram Mount. you just buy the parts, ball and the shaft can be the length you want. I screwed the ball mount to then back of the seat crossover. It basically hangs into the baggage area and is level. Works great.
I used the tray that came with the Stratus 2.
