Hi, I have a Becker AR4201 radio in my airplane and have just started flying (2 hours on the tacho, experimental but not an RV). Initially the radio worked great (after I got the mike jack wiring correct). Halfway through the 2nd flight the transmit quit - receive was still good. Plugging in another headset on the ground and the transmit worked OK.
A couple of days later I pushed the airplane out for another flight and no transmit at all. Carrier wave is being transmitted but no modulation (and so side tone in my headset). After trying to figure it out for an hour I put it back together and went flying, still with carrier wave only. After a while I called a local tower (119.0) - loud and clear. Returned to my field (124.1) to the same problem - carrier wave only. What is going on!!!![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I have not been able to test further - but I need to step through the frequency range and find out which freqs work and which do not. This is a very simple airplane with no intercom, headset connected directly to the radio. Receive is good all the time, on all freqs tried so far. Radio shows the transmit arrow whenever the PTT is pushed, and puts out carrier wave. Why is it modulating on some freqs and not others? Headset works in other aircraft (have tried 3 so far with same results).
Does anyone have any idea about what is going on?
Any suggestions gratefully received.
Pete
Pete
